Hi. how do i change language in Homepage Product Section
Discussion in 'Quick Online Shop WordPress Theme' started by kitekat77, Feb 8, 2017.
  1. kitekat77
    kitekat77 Member
    I will like to change: "view Details" to my own language danish. "Se mere"
    And i will like to remove "Comments are closed." i basket and check out areas.
    I really hope you can help me thanks in advance.
  2. Naveen
    You can share the screenshots of the concerned areas of the theme and your WordPress admin credentials at [email protected]
    We will remove the required elements from your site.
    Warm Regards!
    Naveen Kolhe
