Hide or Minimize Slider Index
Discussion in 'Infoway WordPress Theme' started by johnnyb719, Jul 17, 2013.
  1. johnnyb719
    johnnyb719 New Member
    my site : http://www.webvertz.net
    Is it possible make it so that that the black part of the slider that contains the slide title and description would hide automatically and unhide when rolled over?
    Also shouldn't the box that contains each individual slide title and description expand when mouse is on top of it? Otherwise the description only shows top half of the first line in the description field.
  3. johnnyb719
    Well then there is something you should specifiy in the backend. In the sliders section you say to make the image file a certain size, which is technically true. However in reality most of that is going to get covered up by the slide titles and description to the right. Now I have to go back and edit all the slides I've created to fit that. It would be nice if there was something specifying that not all the image is going to show up and saying what dimensions are going to show so that when your users are creating the slides they'll know.
