Home Banner Problem
Discussion in 'Quick Online Shop WordPress Theme' started by tcg007, Apr 21, 2018.
  1. tcg007
    tcg007 Member
    I am trying to replace the default banner BUT it is as if it does not 'stick" . I sometimes getting it to work for a few minutes and then it defaults back to the theme banner. What am I doing wrong?
  2. akbar92
    Greeting from InkThemes,
    We need WordPress admin credentials to figure out the issue.
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    Akbar
  3. tcg007
    tcg007 Member
    Ok I will send it to you
  4. akbar92
    Akbar
  5. tcg007
    tcg007 Member
    Hi Akbar,
    Thanks for fixing the banner. I need you to tell me how you fixed this because we have 45+ of these sites build for clients and we have the same problem on all of them.
    Is it a plugin - can it be fixed with code?
    Please help
  6. akbar92
    Will you please share your website URL here?
    So that we can assist you accordingly.
    Akbar
