Home Feature Problems
Discussion in 'Foogo Pro WordPress Theme' started by richarbran, Oct 26, 2015.
  1. richarbran
    richarbran Member
    1. All 4 home feature images are the recommended 144x144 size but the 4th one drops down a row. I want all four in a row.
    2. I'd like to change the font size of the home feature text headings or be able to increase the width of each to accommodate more text in one line (see Crown and Bridge is on two lines).
    3. I'd like all 4 home feature sections to be centered, right now they are right justified.
    4. Can you provide me with code to remove the video on the home page?
    5. Also code to make the blog post section full width?
    Thank you in advance.
  2. richarbran
    richarbran Member
    By adding extra text to the home features I was able to get them to center and space properly. So all that I need is the code for #4 and #5. Thank you.
  3. priya
    As per your above issues, solutions are accordingly...
    1) All 4 home feature images are the recommended 144x144 size but the 4th one drops down a row. I want all four in a row.
    I have checked this issue at our end but didn't find such an issue..
    2) I'd like to change the font size of the home feature text headings or be able to increase the width of each to accommodate more text in one line.
    For this, please paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard.
    #site_features .f-content span.f-heading {
        font-size: 25px;
    3) I'd like all 4 home feature sections to be centered, right now they are right justified.
    Please provide us URL of your site.
    4 & 5) Can you provide me with code to remove the video on the home page? & code to make the blog post section full width?
    For these issues, you just have to follow the screenshots given below.
    Note: Adjust numeric value as per your requirement.
    For your knowledge, I am using wp-editor to edit the file.
