Home Page Blog post On/Off - Not working
Discussion in 'Traffica WordPress Theme' started by danefto, Dec 20, 2013.
  1. danefto
    danefto New Member
    This was working until I set a featured image in one of the blog posts.
    Now the blog section on the home page won't show, even if i have selected it to show in admin.
  2. danefto
    danefto New Member
    I've found a bug!
    If you do not have an image within the blog post itself then this will have an affect on other sections on the homepage!
    It will mean that the blog posts will not appear on the homepage and it affect the expanding of the accordion.
    Can you look into this and offer a permanent fix?
  3. Piyush
  4. Piyush
  5. collectme
    collectme New Member
    Hello, I am having the same issue. I have downloaded and activated the new version as per your link. If I do add an Image to my post, only the "
    Home Page Blog Heading Text" appears with the image scrolling below that, No text. If I remove the Image from the Blog post. Nothing Appears on the Home page. Please assist ?
  6. sameerwalkar
    sameerwalkar Guest
    For your information, This is our theme's built in feature that all the blog posts will appear in the slider without text and if you will not set the feature image then it will not appear the slider.
    But if you want to add blog post along with images and texts in the home page then you have to customize it from the source code.
    Sameer
