Home Page Bottom Sectio
Discussion in 'Slice WordPress Theme' started by niallg, Oct 6, 2014.
  1. niallg
    niallg Member
    I need to change the Text Colour, Text Size, Upper or Lower Case, Make Bold and Font Size.
    in :
    Home Page Bottom Section Heading
    Home Page Bottom Section Description
    Page Caption
    and Also:
    If I decide not to put any text in these boxes , how to stop your default text from showing.
    The URL is : www.gtksamplepages.com/wp
    Niall
  2. Yogesh
    Yogesh Guest
    1. Edit custom.js file as shown below in screenshot.
    2. To change font-size etc of bottom heading and bottom description use following css in Custom CSS.
    .index-fullwidth h2 {
    font-size: size according to you (eg. 26px);
    color: your color(eg. green);
    font-weight: 700;
    text-transform: uppercase;
    .index-fullwidth p {
    font-size:  size according to you (eg. 12px);
    color: your color(eg. red);
    font-weight: 500;
    text-transform: lowercase;
    3. If you don't want bottom text then put some spaces in bottom feature setting in theme option panel or use following css in Custom CSS.
    .index-fullwidth {
    It will resolve your issue.
    Yogesh Bhade
  3. niallg
    niallg Member
    Hi Yogesh,
    thank you for your assistance, it worked, however I need css to change the Page Caption at the very bottom in the Blue Bar over the small logos on www.gtksamplepages.com/wp.
    Your customer service is excellent, I am going to change all of my sites over to Ink Themes.
    Regards
    Niall
  4. Yogesh
    Yogesh Guest
    Your site is not working now so when your site will work i will find solution for it.
    Yogesh Bhade
  5. niallg
    niallg Member
    Hi Yogesh,
    the bandwidth issue has been fixed.
    Regards
    Niall
  6. Yogesh
    Yogesh Guest
    Your bandwidth issue has not fixed.
    Yogesh Bhade
  7. niallg
    niallg Member
    Hi Yogesh,
    the bandwidth issue is now fixed, this time, I made it unlimited.
    Regards
    Niall
  8. Yogesh
    Yogesh Guest
    .content-bottom {
    color: white;
    Yogesh Bhade
