Home Page buttons
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by dme_2, Dec 29, 2017.
  1. dme_2
    dme_2 New Member
    How do we remove the guge grey buttons from the home page, which seem designed more for the administrator than for the public?
  2. akbar92
    Akbar
  3. astermedia
    astermedia Member
    The Netherlands
    I solved the problem, thanks.
    Rgds.,
    Steven
  4. akbar92
    Sounds Great. :)
