Home Page Editor
Discussion in 'GeoCraft WordPress Theme' started by karenfriendsmith, May 5, 2015.
  1. karenfriendsmith
    karenfriendsmith New Member
    I need to remove the following code from my Home Page (www.sharesanmarcos.com), but cannot locate it to edit the php. Where can I access the Home Page code?
    The code I need to remove is:
    <!-- AddThis Button BEGIN -->
    <div class="addthis_toolbox addthis_floating_style addthis_counter_style" style="left:50px;top:50px;">
    <a class="addthis_button_
    facebook_like" fb:like:layout="box_count"></a>
    <a class="addthis_button_tweet" tw:count="vertical"></a>
    <a class="addthis_button_google_plusone" g:plusone:size="tall"></a>
    <a class="addthis_counter"></a>
    </div>
    <script type="text/javascript" src="http://s7.addthis.com/js/250/addthis_widget.js#pubid="></script>
    <!-- AddThis Button END -->
  2. sameerwalkar
    sameerwalkar Guest
    Hope doing great.
    To remove it you can use this CSS as well it will also work for you in removing that
    .addthis_toolbox.addthis_floating_style.addthis_counter_style {
    But still if you need to check in the source code then you can check in front-page.php file. But it's recommended to avoid source code customization if possible.
    Hope it will solve your issue.
  3. karenfriendsmith
    Perfect. Thank you! Problem resolved.
