Home Page Footer
Discussion in 'Local Business WordPress Theme' started by skon, Feb 13, 2013.
  1. skon
    skon Member
    Norwood, Massachusetts USA
    I put widgets in the first, second and third footer areas on the home page and I'd like them to appear only on the first page, but not on the other pages. How can I do this?
  3. skon
    skon Member
    Thanks Gourav, This did the trick as well.
  4. skon
    skon Member
    I installed the Dynamic Widgets as you suggested. I was able to display widgets on the home page without being on the other pages. So thought I could control which widgets appear on which screens. However, when I create new pages, default text is being displayed in the first, second and third "footer widget areas". I inserted a screen shot for you.
    How do I insert or delete information from the widgets on the other pages? I can't find a separate set of widgets for those pages.
  5. Gourav
  6. skon
    skon Member
    I edited the footer widgets and have set the dynamic widgets settings so the widgets I edited show up only on my home page. However the original widgets: Shortly About Us, Contact Us (Indian contact), Google Map (Indian Location) appear on the other pages. I don't know how to find the second instance of these widgets so I can set the dynamic widget settings for them. I hope my explanation is clear.
  7. skon
    skon Member
    Problem solved.
    It was an issue with the Dynamic Widget. http://www.qurl.nl/dynamic-widgets/faq/: "Dynamic Widgets is not following the rules I've set" Change advanced settings to "use the old style" and try again.
    I had to go through and reset the Dynamic Widgets setting for each widget, but then it worked fine.
