The site with the problems is pngsupport.com. You can see where the home page obviously is problematic. I tried to find the home option under settings to make the home page static, but there is no home option. Thanks in advance for you time and help!
Hello, You can put the content for the home page through the theme option panel in your dashboard. You need not to select it from the reading setting panel. So make the default setting as shown in the image given below This will solve your issue, if not, then update your theme. Download the updated copy of Infoway Theme from the members area (http://inkthemes.com/members/member) and, upload and activate it in your dashboard. Follow the link given below for reference. http://www.inkthemes.com/how-to-update-a-premium-theme-by-inkthemes/05/
Hello, Could you please provide the following information listed below. Thread Link: http://www.inkthemes.com/community/threads/home-page-format-problem.10880/ Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected] . We will check and try to resolve your issue.
The site still looks the same. What plugin did you deactivate? I have cleaned all my caches and can't see a change.
You guys are great. I just deactivated a plugin and it works great! What plugin should I use for SEO that won't mess up the format?
Hello, You can try WordPress SEO by Yoast plugin for this issue. Download it from the link given below and install it from the Plugins panel (Plugins ->Add New ->Upload) in your Dashboard. https://wordpress.org/plugins/wordpress-seo/ I hope this will solve your issue.
