Home page has translation?
Discussion in 'Appointway WordPress Theme' started by mariam, Nov 22, 2013.
  1. mariam
    mariam New Member
    If you want to translate the theme in one language then follow the link given below
    http://www.inkthemes.com/how-to-cre...-of-wordpress-theme-in-multiple-languages/02/
    If you want to translate the theme in multiple language then you can achieve this through
    1. qTranslate plugin,
    See the link for reference
    http://www.inkthemes.com/how-to-translate-your-wordpress-website-using-qtranslate-plugin/01/
    Or
    2. Google Language Translator plugin,
    http://www.inkthemes.com/make-multi-language-website-by-using-google-language-translator-plugin/08/
    I hope this will help you.
  3. mariam
    mariam New Member
    I have already a translation plugin but how can I translate the home's page differents parts such as : main heading, subheading, three colomns features and the testimonial? That is my question!
  4. Nitesh
    To translate home page content you can use code given below in the theme options panel.
    <!–:en–>Your text in English.<!–:–>
    <!–:de–>Your text in Deutsch<!–:–>
    <!–:it–>Your text in Italiano<!–:–>
    <!–:fr–>Your text in Français<!–:–>
    And also go through link given below. Specially point number 6.
    Nitesh Raghuwanshi
  5. carlesubach
    carlesubach New Member
    Hello Nitesh and everyone on inkthemes,
    We have a problem trying to translate our homepage: we've developed a website using Cloriato Pro Theme and create a multilanguage site using wpml but it doesn't allows us to translate the homepage (text in them options panel). We've been researching but it seems to be no option to translate Cloriato's homepage... Can you help us please? it is a must to have the Homepage in both languages: English and Spanish.
    Thank you,
    Maricarmen.
  6. Gourav
    You can use qTranslate plugin for translating the Cloriato theme, download it from WordPress.org and upload it.
    http://wordpress.org/plugins/qtranslate/
    Also check the link given below
    http://www.inkthemes.com/how-to-tra...website-using-qtranslate-plugin/01/?no-dialog
    I hope it will help you.
    Gourav Shrivastava
  7. mariam
    mariam New Member
    So...qtranslate you tell me is not working...I installed GLT but I want to add my own translations for pages, articles from the blog and media...not to let google to translate itself cause you know well how translates...:-(
    How do I do it?
    Please help!
  8. praveen
    praveen Support Staff
    Hello, Mariam!
    As per your requirement, I would like to suggest you "Polylang" Plugins which will allow you to translate your website manually.
    Here is the plugin link :- https://wordpress.org/plugins/polylang/
    Praveen
  9. mariam
    mariam New Member
    Yes...I used polylang but I don't know how to translate in 4 languages...with 2 works great but I need in 4 different languages...How to do it?
  10. mariam
    mariam New Member
    And about translating home page content I used the codes given above and all languages are shown simultaneously and I want only the language selected by the user. Look in the print screen attached...
  11. sameerwalkar
    sameerwalkar Guest
  12. mariam
    mariam New Member
    Yes...I can read in 2 days the whole documentation...I thought you know the plugin and used...but seems not.
    I used polylang for 3 years and works fine for 2 languages. When I add 4 languages...the firsts 2 work fine...the last 2 doesn't show on the homepage the flags. :-(
    The other problem I have...with the translation of the hope page featured texts..how do I do it?
    I used that code you gave in the past messages...but dpesn't work. I sent u pics with that. Any idea...how do I do it?
  13. mariam
    mariam New Member
  14. sameerwalkar
    sameerwalkar Guest
    Hello Mariam,
    Thanks for sharing the information with us.
    I have forwarded your query to our technical team to check if wpml-config.xml is available with the theme as suggest by one of the member in the support forum.
    If not then we will create the one and provide you the same. so that you can able to translate it.
    Thanks for your cooperation and patience.
  15. mariam
    mariam New Member
    The problem with the flags is solved.
    Remain the problem with the translation of front page ( with all areas from the theme) in 4 languages. Have any idea?
  16. sameerwalkar
    sameerwalkar Guest
