Hello! Is there a way to make the Home page Main header and the Sub Header to have more then one line as well as center the text? Ex: 24/7 Water Damage 877-24-Flood My website is: www.damageawayusa.com/wordpress Thanks! Tim
Hello, Could you please explain your issue little more and also specify it with the help of screenshot images.
Sure thing! I would like to have multiple lines of text in the main header and/or the Sub header. For example in the picture in closed I would like to take my sub header and add more text, but make it two separate lines so it would read something like: For Water Damage services in Temecula call 877-24 FLOOD Hopefully that is clearer. Thanks! Tim
Hello, You can use line break tag (i.e <br>) to break the sentence for next line. For example: You can put the text like given below in the Home Page Main Heading section of your dashboard. Code: For Water Damage services<br> in Temecula call <br> 877-24 FLOOD Similarly, do the same for Home Page Sub Heading Section. I hope it will help you.
