home page layout
Discussion in 'Compass WordPress Theme' started by smarta, Mar 8, 2016.
  1. smarta
    smarta Member
    on the site at
    http://smartartshosting.com.au/amarco-iluka/
    I would like to have the following
    - the text currently in "testimonial" cover the whole page width therefore removing the "Latest from the Blog" section
    - I would also like to remove both testimonial images & website names/links
    can you advise the custom CSS to do this please
    For issue #1,
    .feature_blog_content {
    For issue #2,
    Please provide us some edited screenshot of the concerned area so that I can better assist you...
  3. smarta
    smarta Member
    Hi Priya
    Thank you - but that removes the whole section
    I want to remove the "Lastest form the Blog" section completley (my client will not be using posts)
    then change the testimonials section so that
    - it has no images
    - it is plain text
    - it goes across the whole page
    (or alternately replace the whole feature_blog_content section with a text field)
    I have attached a screen shot to show what I would like
    I will send log-in deatails
    You would be glad to know that I have done the changes in your site as per your requirement...
    Kindly check your site and acknowledge the same..
