Home Page Settings: Shortcode supported?
Discussion in 'Cloriato WordPress Theme' started by breecifer, Aug 1, 2013.
  1. breecifer
    breecifer New Member
    Hello
    I've recently been tasked to update the home page of a website I support to have the home page contain a link to a form widget I'm using. I've not had luck with Cloriato's Theme Options Home Page Settings | Homepage Heading Description text-field.
    Does the Homepage Heading Description text-field support shortcode? Do I need to append a wrapper to this shortcode so it will work?
    Example: [iphorm_popup id="2" name="Summer Camp 2013 Survey"]Online Survey for Summer Camp 2013[/iphorm_popup]
    Can you offer any other solutions so I could have a direct link from my homepage to the form? Many thanks on your support for this.
    Shortcode do not works in the Theme option panel but it works on the widget area.
    So, go to the Widget panel (Appearance > Widgets) in your dashboard, and then drag and drop the text widget in the Footer Widget Area
    and then paste your shortcode in the Text Widget content area.
