Home Page Slider not centered
Discussion in 'Smartbooking-Appointment Booking WordPress Theme.' started by jungledude, Jul 29, 2016.
  1. jungledude
    jungledude New Member
    Orange County, California
    Since my last fix, the slider on the home page is not centered. Can you tell me where the code belongs to center it? Site is www.PhotosByAppointment.com, and uses a black background which required several changes to make text show up, so I hesitate to just replace the theme with a newer one.
    #slider1_container {
        top: 79px;
        left: 75px;
    Note: Change the numeric value as per your requirement..
  3. jungledude
    This solution looks like it is dependent on a particular size display, when I want the slider to be centered horizontally on all displays. Is there a way to use a "center"command?
    Please use below code..
    .slides img {
        left: 0 !important;
