Greetings! The Home Page Top Image on the Foogo theme displays just fine on an iPad, but on my iPhone 6, the Home Page Top Image is not responsive. [It's centered and cut off on the sides.] Is there a way this can be fixed so that it reduces to the smaller screen size? And, as always, thank you for your advice and direction, Glory P.S. If needed, login credentials for the site were sent earlier, with subject line: MERGE
Hi, Greetings from InkThemes, I just visited your website but didn't notice the issue as you mentioned above. It would be better for us to understand your query with the help of some edited screenshots of the concerned areas of your site. So that we can deliver you an exact and appropriate solution to you, Looking forward to hearing from you soon. Thanks & Regards! Akbar InkThemes.com PS: You can create your screenshots using screenpresso (http://www.screenpresso.com).
