Hi -- I've downloaded the lastest version of Colorway, and I'm having an issue with the Home Page Widget Section Heading. It's not showing. I can get the widget headers to show, but the overall header won't. See attached screen shot: As you can see, the blog header isn't in line with the Widget Header. How do I get the Widget Header to display. I've added it to the "Home Page Widget Section." But that does not work. Thanks
Hi, Greetings from InkThemes! Could you please provide us 'URL' of your site so that we can better assist you? Thanks & Regards! Priyanka InkThemes.com
It's a dev site, and the actual domain will eventually change...but, here it is: http://693.36f.myftpupload.com/
Hello, I have checked your site and would like to tell you that you are using 3.6.5 version of the theme whereas 3.6.8 is available in the members area.. So if you haven't customized source code of the theme, you are kindly suggested to reinstall the latest version of the theme from the members area. Here're the steps of doing so... Download the ColorWay theme by logging in your members account: http://inkthemes.com/members/member Next, you have to extract the zip file and rename that folder colorway like colorway_new, Again, you would need to create a zip file of that renamed folder (say: colorway_new.zip), Now, upload the theme in your WordPress from Dashboard->Appearance->Themes->Add New, Then, activate your theme, This way you can install and activate your updated version in your site, keeping the copy of your older version in your WordPress Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
