Home Page
Discussion in 'Compass WordPress Theme' started by bgdrew03, Apr 30, 2015.
  1. bgdrew03
    bgdrew03 Guest
    I would like to keep the testimonials section, however I would like to make the blog section static Text instead of Blog posts. How would I do that?
    I would also want to add a lead capture or contact form widget to the home page as well, maybe a floating one if possible, do you know of a good plugin that would allow me to do that? Thanks in advance for all your help!
  2. sameerwalkar
    sameerwalkar Guest
    If you wish to remove the Blog Post and want to make it as a static Text instead then you need to do some code customization in source code:
    Kindly follow steps mentioned in the video link :
    http://screenpresso.com/=Uqybe
    Also for lead capture plugin: you can try one of these stated plugins below:
    1. WordPress Lead Capture Plugin: http://www.inkthemes.com/plugin/wordpress-lead-capture-plugin/
    2. FormGet-Sliding Contact form: https://wordpress.org/plugins/sliding-contact-form-by-formget/
    Hope it will solve your issue.
