Home Slider - Our clients Logos
Discussion in 'BlackWell-WordPress Business Theme.' started by ckoulatsi, Dec 1, 2017.
  1. ckoulatsi
    ckoulatsi New Member
    Hello i have just bought the theme and installed foodmaster demo.
    I have created a child theme and all is well except some things that do not match with the online demo site.
    1. I would like to edit the slide transition on my homepage top slider to fade (The homepage slider in my theme is flexslider but in the online demo is blackwell slider with fade transition)
    2. the client sections withe the logos is not working, the logos does not appear even if a i have set the images on the backend, there are only the arrows (next & before)
  2. akbar92
    1. Will you please share your website URL here?
    2. We need WordPress admin credentials to figure out the issue.
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    Akbar
  3. svonfischer
    svonfischer New Member
    Was this ever resolved? I am having the same issue with the client section.
  4. akbar92
    Hello
    Greeting from InkThemes,
    We will look into the issue and kindly elaborate it a bit more.
    And send the below-mentioned credential details at [email protected] along with the thread link.
    We will do the needful for you.
    Akbar
  5. hablemosclaro
    hablemosclaro New Member
    Hello, the images of the logos in the secction clients are not loaded
  6. shemaela21
    shemaela21 Guest Staff Member
    Warm Wishes From InkThemes,
    Have you set the image from the theme options panel if not then kindly set it.
    If the issue still exists then, kindly send the below-mentioned credential details at [email protected].
    We will check the issue and let you know about it.
    Shemaela
