Homepage feature links notclickable
Discussion in 'BizWay WordPress Theme' started by evolve, Feb 1, 2013.
  1. evolve
    evolve New Member
    hi,
    I cannot get the homepage feature IMAGES to be clickable. The heading works when I insert the URL in the theme options section. However, even though the pointer changes to a hand when I hover over the images it does not work. The documentation says "write the link of the feature IMAGE" .This is frustrating as it's one of the reasons I purchased the Pro theme.
    Please can you help.
    Featured images are clickable. I think you are using themes default featured images. Add your own images, Links will work fine.
