homepage feature want 3 not 4 boxes
Discussion in 'Traffica WordPress Theme' started by sandradohn, Oct 15, 2020.
  1. sandradohn
    sandradohn Member
    HI There, I have adjusted the theme setting to show 3 boxes on the hoe page under the slider but 4 are still showing. Please advise. Thanks, Sandra
  2. shemaela21
    shemaela21 Guest Staff Member
    Hello Sandra,
    Warm Wishes From InkThemes,
    You had not made the settings properly from the theme options panel.
    So we have made the settings for you, now the feature section looks fine.
    Kindly once check it on your end and let us know about it.
    Shemaela
  3. sandradohn
    sandradohn Member
    Hi There, It is still showing 4 boxes, not three. Please advise. Thanks, Sandra
  4. shemaela21
    Hello Sandra,
    I would like to inform you that we are working on the issues you have in the theme.
    Kindly be patient until we get back to you.
    Your patience will be highly appreciated.
    Shemaela
