Homepage Featured Sect and Full Cols Sec Removal and Edit to Left Colmun Side
Discussion in 'Figero WordPress Theme' started by jalex860, May 20, 2018.
  1. jalex860
    jalex860 New Member
    I have 3 questions that I hope you can help me with:
    1. How do I completely remove the Homepage Featured Section?
    2. How do I remove the Full Cols Section?
    3. Is there a way to remove the Left Column Side of the Homepage Two Column Section and have the Right Column Side move over to the left and sit across the span of both sections?
    Thanks in advance,
    Joanne
  2. akbar92
    Thanks for reaching to us,
    To remove the Homepage Featured Section, just paste the code given below in Custom CSS section.
    .index-container .feature-index {
    And for (2 & 3):
    Akbar
  3. jalex860
    jalex860 New Member
  4. jalex860
    jalex860 New Member
    Thanks Akbar. Id like to remove everything in the attached picture:
  5. jalex860
    jalex860 New Member
    My end goal is only have what I have featured in the attached pic on the homepage however I wanted to have the Right Column Side moved over to the left and sit across the span of both sections so I would then have only one column listed.
  6. akbar92
    Greeting from InkThemes,
    We need WordPress admin credentials to configure it.
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    Akbar
  7. jalex860
    jalex860 New Member
  8. jalex860
    jalex860 New Member
    Thank you, I just sent the email with the requested credentials and thread link.
    Thanks in advance,
    Joanne
  9. akbar92
    Hello Joanne,
    I am pleased to inform you that- I have modified the required changes, Kindly visit your site and acknowledge us for the same.
    Akbar
