Homepage (index.php) blog not working
Discussion in 'BlackBird WordPress Theme' started by akschoeck, Feb 19, 2015.
  1. akschoeck
    akschoeck New Member
    Hi there! My website is http://leader-development.net/ that uses this theme.
    I'm trying to get the home page to be the blog, but keep encountering one of two issues.
    I can either set the home page to "Your Latest Posts" through the WP backend Settings > Reading or I can set up a normal page with the template of "Blog" and set the home page to that templated page. But I'm having issues with both of these solutions.
    When I set the homepage to "Your Latest Posts", it only shows an excerpt of the most recent post with no pagination. I would like it to show the 10 most recent posts with options to view others on other pages (pagination). Under the Settings > Reading option in the WP backend, I did also check here to make sure that it was set to show 10 posts.
    If I try to make a separate page with the template of "Blog", I get the list of blog posts as I want, and it even has pagination. The issue now is that the pagination does not work. When I click to go to page 2, the URL goes from http://leader-development.net/ to http://leader-development.net/page/2/ (or whatever other page I pick), but still only displays the first page of posts.
    In addition, the page I created for the Blog template was titles "Blog". The address is here: http://leader-development.net/blog/. The pagination on this page works perfectly fine, and http://leader-development.net/blog/page/2/ takes me to the second page of blog posts.
    I've tried adding other pagination PHP code to the index.php page, but they all result in the same thing. Which makes me think it might be an issue with the permalink settings? But I've tried multiple permalink settings, and they all resulted in these same errors. I've tried disabling all plugins to see if it was a plugin issue, and have concluded that it has nothing to do with my plugins (the issue persisted with all plugins turned off).
    Any help would be greatly appreciated!
  2. Pramod
    Pramod Guest
    This thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    Pramod Patel
  3. akschoeck
    Done, thank you.
  4. Pramod
    Pramod Guest
    Hello !
    We have fixed this issue please have a look.
    Pramod
