Homepage Product Description
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by rogerschnur, Jan 5, 2014.
  1. rogerschnur
    rogerschnur Member
    Woo is pulling the info from the Long Description instead of the Short Description. This is problematic for me because I'm using tables and other bullet point info in the Long. How can I change the code so it pulls from the Product Short Description field?
    Hello Roger,
    Theme using Woocommerce plugin functions to show excerpt at the front page. Changing content fetching require customization.
    So the possible solution is, you can add text content of 2, 3 lines at the top of long description. Which will display at the front page.
    Nitesh Raghuwanshi
