homepage, search and fonts
Discussion in 'Elite Pro WordPress Theme' started by interaction, Apr 28, 2015.
  1. interaction
    interaction Member
    Almost finishing my website; just a few last questios.
    How can I change the word Search in the box into Dutch? Changed everything but cannot find it.
    Have now on my homepage http://www_hotelspa_nl.017.bho.nu/wordpress/ the latest posts. Is it possible to have posts only of one specific category listed here?
    If you look at the font of the headings (the one in the slider for example) looks different and a blit blurry; not like your examples. How can I repair this?
    the only changes I made in the custom CSS are
    .index-content img {
    border: none;
    ul.post_meta {
    display: none !important;
    a {
    text-decoration:none;
    color:#f0a51e;
    a:hover {
    text-decoration:underline
    h4 {
    font-family:Verdana;
    color: #f0a51e;
    font-weight: bold;
    Thanks!
    Yvonne
  2. praveen
    praveen Support Staff
    Hello!
    1> Please follow the screenshot given below.
    2> It is possible but need some customization in the source code. So, send us your website WordPress login details at [email protected] along with the thread link.
    Also mentioned that which category you want in the homepage.
    3>For your information, we are using cufon.js in this theme which convert text/headings into images.
    So, first you have to disable it.
    Now, paste the code given below in Custom CSS section
    h1, h2, h3, h4, h5, h6{
    font-family: "champagne & Limousines";
    line-height: 27px;
    font-weight: bold;
    .flex-caption h1 {
      padding-top: 30px;
      color: #333;
    Praveen
  3. interaction
    interaction Member
    Hi Praveen,
    Thanks. will send a mail to support.
    About 3; I am not using Figoro and what ever file I open with Elite Pro I do not get a screenshot like yours.
    thanks!
    Yvonne
  4. praveen
    Praveen
  5. interaction
    interaction Member
    thanks! solved!
