Homepage Slide is lock on 1920 px wide x 654 px height, how can i put in picture wt higher height
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by effyeweb, Dec 6, 2014.
  1. effyeweb
    effyeweb Member
    Homepage Slide is lock on 1920 px wide x 654 px height, how can i put in picture with higher height
    maybe 1920px wide * 800px Height or any figure..... currently it stretch the slider images
  2. Yogesh
    Yogesh Guest
    .sl-slider, .bg-img img {
    height: 800px !important;
    Adjust height of slider and slider images by changing height value in above code according to your need.
    It will resolve your issue.
    Yogesh Bhade
  3. effyeweb
    effyeweb Member
    can i put it to auto, so if have different height of slider?
  4. Yogesh
    Yogesh Guest
    You can try "height:auto" but i will advise you to use a specific height images.
    Yogesh Bhade
  5. effyeweb
    effyeweb Member
    ok, thanks a lot
