Homepage Slider Not Showing Up- On Logout
Discussion in 'ButterBelly WordPress Theme' started by dhodzpc, Jun 15, 2014.
  1. dhodzpc
    dhodzpc New Member
    Hello guys,
    This new site I am building is about ready to go without noticing that the homepage slider is not showing up when I am logged out of the WP dashboard. It shows OK though when I am logged in. Can you please help me configure what's the problem behind. I've got no idea at all why is it like this.
    Link is here: http://bitly.com/tanmrapd
    On the styling options, I've got the following optimizations:
    div.header_container {
    .flex-caption-wrapper {
    .feature_mid_content {
    display:none;
    .feature_blog_content {
    display:none;
    .feature-content {
    padding-bottom: 0px;
    margin-bottom: 0px;
    .footer_container {
    display: none;}
    Thank you!
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    I will check your issue.
    Gourav Shrivastava
  3. dhodzpc
    dhodzpc New Member
    Hi Gourav,
    Thanks for your help. I just found out that it was not compatible with WP Fastest Cache. I really liked this plugin for it's lightweight and truly works but this is already the second time that this plugin has compatibility issues with inkthemes; the second encounter I had was with the squirrel theme.
    Nevertheless, thanks for Inkthemes- you have made such a life a of web developer so easy (literally one-click installation)!
    Now here's how the website looks with customized butterfly theme: http://bitly.com/tanmrapd
    Thanks heaps!
  4. Gourav
    Our themes are compatible with almost all the plugin available in WordPress.org but there are thousands of plugin available on WordPress.org and some are regularly updating and some are not updated from many years therefore it is not possible for us to check every plugin with our theme, So you can search any alternative of that plugin.
    Or
    You can also contact to plugin related support forum. They will help you.
    Gourav Shrivastava
