Hi, See screen shot.. a small issue with the homepage Two cols.. the two sections are not parallel - the right section looks slightly lower than the left.. is there any way to fix this?
SOLVED: If anyone is using image on the Homepage 2 Cols, you will have the issue that I am having. Simply add this code to your Styling Options: .testimonial_holder { padding: 0px; }
