How Can I Disable Business Ratings & Business Reviews
Discussion in 'GeoCraft WordPress Theme' started by blessedjeff, Oct 23, 2015.
  1. blessedjeff
    blessedjeff New Member
    My client does not want to display business listing ratings or business listing reviews. How can I disable.
    Could you please provide us 'URL' of your site with some edited screenshot of the concerned area so that we can better assist you?
  3. blessedjeff
    I have attached a screenshot from my site.
    To remove business listing ratings, you just have to paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard.
    .article_rating {
        display: none !important;
    To remove business listing reviews, Please follow the screenshot given below.
  5. joshuasloan
    joshuasloan Member
    Can the removal of business listing reviews be done with the Child Theme as well?
  6. priya
    Yes, that will work with the child theme as well..
