How can I save Geocraft theme settings
Discussion in 'GeoCraft WordPress Theme' started by imranite, Jul 26, 2015.
  1. imranite
    imranite Member
    I will like to know how I can save my theme settings so that I can re-use them for other sites.
    Imran
  2. praveen
    praveen Support Staff
    Hi Imran,
    Unfortunately, there is no any way to preserve the theme setting to use them for other sites.
    All the settings will be saved in your databases and when you switched to another sites, database changes. So, it's not possible to use the settings.
    Hope I made it clear to you.
    Let me know if need further help.
    Praveen
