How can the footer copyright box be increased in length?
Discussion in 'GeoCraft WordPress Theme' started by webedge, Oct 18, 2013.
  1. webedge
    webedge Member
    Does anyone know how to increase the length of the displayed Footer copyright? Ours is wrapping around to display 2 lines instead of 1.
    Can really use some help on this one.
    Thanks!
  2. jsal2
    jsal2 Member
    Hi webedge, it would help to be able to see what you mean; can you provide a link or image? Thx
  3. webedge
    webedge Member
    Turns out that this not a problem ... Depending on the "Width" of the browser window the footer Copyright box can wrap around to two lines since the width of the browser is too small for the Theme.
    At lest this was an easy one to understand :)
    So this question can be labelled as Fixed or Closed.
