I am using Homepage 1 format. I want to CSS codes on how to disable Row 1, Row, 2 Row 3, Row 4 but still be able to pull it back later if i need to. I dont want to remove the codes just disable it.
Do you mean in homepage1 settings?? like the on/off button shown in image?? I played with most of these settings but i dont see any changes. Can you be more specific in pointing us to the right directions. I think I can speak for a lot of inkthemes customers, not all of us know coding or programming.
I tried this css for example but like i said im not a coder. this code didn't work Code: .latest-by-reviews { display: none; }
I just saw that the sections I wanted disabled were deleted. I checked the theme editor and support erased the codes for particular sections which means I can't enable them back as I see fit. The changes happened with no other notes in my email or here at the forum. It just magically materialized. As much as I appreciate the help, I really like to learn too. and maybe others who may use the same template in the future. Thanks again.
Hello sangermike your website is http://greenvalleycollision.com/, right? i've changed layout "Home Layout 1" as your request by email. Also i was attaching home-layout-1.php file for you via email (check your email) if your client want enable it, you can re-upload it to wp-content\themes\newszine\templates folder. Thanks
