How do i change color in header, footer and in main-menu ?
Discussion in 'BusinessGrow One Page WordPress Theme' started by kitekat77, Sep 18, 2016.
  1. kitekat77
    kitekat77 Member
    1#I don't want to use the Fourth Footer Widget Area, but it won't let me drag it away. How do I remove it completely? I'm at http://www.akupunkturkbh.dk. Thanks
    2# How do i change the color of the footer areas from black to gray” the same color as where it say “Cristiaan Iuul tilbyder”?
    3# How do i change the color in the main-menu bar from white to orange?
    4# How to i change the color of the top header “ where the phone nr is, from dark gray to the same gray as in the area where it say “Cristiaan Iuul tilbyder” ?
    5# how do i remove the Hover Color in main menu ?
    Than you in advance
    Solutions to your above issues are given below accordingly, you just need to paste the code given below in Custom CSS field (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard.
    1) I don't want to use the Fourth Footer Widget Area, but it won't let me drag it away.
    Code is given below,
    .footer_columns.last {
    2) How do i change the color of the footer areas from black to gray” the same color as where it say “Cristiaan Iuul tilbyder”?
    .footer {
        background: #7b7b7b;
    3) How do i change the color in the main-menu bar from white to orange?
    #menu li.current-menu-item a, #menu li.current-menu-parent a, #menu li.current_page_parent a, #menu li a.selected, #menu li.current_page_item a, #menu .ddsmoothmenu li li a {
        background: #FAAC58;
    4) How to i change the color of the top header “ where the phone nr is, from dark gray to the same gray as in the area where it say “Cristiaan Iuul tilbyder” ?
    .social_wrapper {
    5) how do i remove the Hover Color in main menu ?
    #menu li a:hover {
        background: cornsilk;
    Note: You can change color as per your requirement..
