How do I create vanity URLs
Discussion in 'Traffica WordPress Theme' started by ttsmarketing, Jan 15, 2018.
  1. ttsmarketing
    ttsmarketing New Member
    I would like to have custom URLs on my site. Is there a setting or plugin for the Traffica theme that I could use?
  2. akbar92
    Thanks for contacting us,
    It seems you are talking about the custom link.
    Yes, you can create a custom link via custom links of the menu. Go to (Dashboard->Appearence->Menus), just follow the attached screenshot.
    Do let me know if you need further assistance.
    I will be glad to assist you.
    Akbar
  3. ttsmarketing
  4. akbar92
    I got it, It seems like you are talking about the permalinks, just change it to the Post Name.
    Go to (Dashboard->Settinsg->Permalinks), just follow the attached screenshot.
    Do let me know if the problem persists.
    Akbar
  5. ttsmarketing
    Morning
    I tried this but then all my pages started showing 404 Not Found.
    Any other ideas?
    Thanks, Sian
  6. akbar92
    Greeting from InkThemes,
    Will you please allow us to check your website dashboard?
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will do the needful.
    Akbar
