How do I display results by business types and location on same site
Discussion in 'GeoCraft WordPress Theme' started by imranite, Feb 8, 2014.
  1. imranite
    imranite Member
    Hi Support,
    How can I make Geocraft theme display results not just by type/category of business but also by the location of business? This way a visitor can find (by way of example) a Dentist located within a specific town or city of a larger area or state.
    Put another way, the directory can focus on the entire state but allow users to find specific services located within parts of the state by way of click through or searches.
    Look forward to a reply.
    Thank you.
    Geocraft theme contain two search fields one for type and another for location.
    Suppose if you want to search "Dentist" in "London". So you can add "Dentist" in first field and "London" in second location field.
    Result will be perfect.
    I hope it will clear your doubt. If not then please contact again.
    Nitesh Raghuwanshi
  3. imranite
    imranite Member
    Hi Nitesh,
    Thanks for the reply. Can you kindly point to a url where I can test this feature.
    Thanks.
  4. Gourav
    You can test that feature in our demo listing website
    http://www.98london.com/
    Gourav Shrivastava
  5. imranite
    imranite Member
    Dear Supprt,
    The 2 search fields described by Nitesh above are not contained in the demo site you sent me.
    Look for to your reply.
  6. Nitesh
    Please check image given below.
    Two search fields given at the header of the page.
    Nitesh Raghuwanshi
  7. imranite
    imranite Member
    Thanks.
    If I want to change the words in the search fields, can you kindly point me to where to do this.
    For example, I could say "Search by business type" and "Search by location". Also, if possible, where can I reduce the font by one point?
    Thank you.
