How do I get Classicraft to Launch
Discussion in 'ClassiCraft WordPress Theme' started by person1968, Jul 8, 2015.
  1. person1968
    person1968 Guest
  2. praveen
    praveen Support Staff
    I am not getting your issue...
    Could you please explain a bit more so that we can assist you ?
    Praveen
  3. myworkshops
    myworkshops New Member
    I Have the same problem When click on a header it opens a blank page and not the full description of product
    in desktop version
  4. nitin
    nitin Guest
    It would be better for us to understand you concern if you could explain your issue in detail, as we couldn't get where are you trying to click on header.
    Just provide us URL of your website along with some edited screenshot of your requirements/concerned area, so that we can assist you accordingly?
    We will try out best to assist you in the best possible way.
    Nitin
