How do i get rid of "COMMENT AND RESPONSES ARE CLOSED and also the COMMENTS ARE CLOSED at the bottom of every page. i know it is probably simple but i am missing it. http://rbpa.ca/client-services/ HELP PLEASE
Go to page.php present in your theme directory and remove the code given below Code: <!--Start Comment Section--> <div class="line"></div> <h3>Comments & Responses</h3> <?php comments_template(); ?> <!--End comment Section--> Sending image for reference Use same process for (single.php, template-fullwidth).
