How do to delete?
Discussion in 'BusinessGrow One Page WordPress Theme' started by perilo, Apr 11, 2016.
  1. perilo
    perilo Member
    You can easily configure it via HomePage Section Sorting option of your dashboard...
    You just all need to go Dashboard=>Appearance=>Customize=>HomePage Setting=>HomePage Section Sorting and remove your unwanted field by clicking on them..
  3. perilo
    perilo Member
  4. perilo
    perilo Member
    Priya, The contact form does not work...home page. And how to translate Your Message and Name?
  5. priya
    To translate the words, please follow the screenshot given below.
    For contact issue screenshot given below..
  6. perilo
    perilo Member
    Thx! Work!
  7. priya
    You're welcome..
