Neither of these areas is accessible through the header footer plugin or the Widgetized areas so how do we change the content?? From your answers on this forum you've deliberately disabled it for both FREE and Pro users; whats the point of that?? We have to contact you; give you log in credentials so you can mess about on our sites - give me a break - are you serious! Take a good look at Astra Themes to see how to provide template libraries properly - Uninstalling this rubbish - Colorways is garbage!!
Hello, Warm Wishes From InkThemes, You can customize the footer area from the customizer panel of the theme. and to edit the footer widget area you will need to edit from the widget area. I hope the above information will help you if it does not let us know we will share the video with you. Regards, Shemaela InkThemes.com
