Dear Sirs, I need your help to add a plugin into my frontpage as I sell English textbooks so it is imperative for me to have a plugin that can collect names, telephone numbers and emails. I have paid for all the full inkthemes themes and I wonder if I could use one of the plugins in one of these themes to do this. Kindly give me the solution thanks.
Hello, There are multiple plugin available in the WordPress.org site. You can search your required plugin from there and install it in your dashboard. You can use that plugin widget in the footer widget area.
Thanks for your response. I need to have a plugin into the top of my frontpage and not in the footer. How do I incorporate the plugin into the top of my frontpage preferably make the slider box smaller and put the plugin next to the slider box. As I sell English textbooks, it is imperative for me to have a top and bold plugin that can collect names, telephone numbers and emails. Once again, thanks.
That will not serve my purpose at all. Can you help to have this plugin as described above on top of the frontpage. Thank you so much.
Hello, Unfortunately there isn't a way to do that with our theme unless you custom code something up. Sorry. Thanks & Regards Gourav Shrivastava
