I have a client mentioning to me that there are no alt tags on his site for the slider pictures. Can you help by telling me how and where to add them? Thank you
Hello, Go to front-page.php present in your theme directory and follow the instruction as shown in image given below Use same process for others also.
Confused. here is what i see on my s ite. can you please show me and thank you <?php if ($check_img_ofset == 0 && inkthemes_get_option('inkthemes_slideimage1') != '') { ?> <div class="slider-video"><?php echo inkthemes_get_option('inkthemes_slideimage1'); ?></div> <?php } else { ?> <?php if (inkthemes_get_option('inkthemes_slideimage1') != '') { ?> <a href="<?php echo inkthemes_get_option('inkthemes_slidelink1'); ?>" > <img src="<?php echo inkthemes_get_option('inkthemes_slideimage1'); ?>" alt="Slide 1"/> </a> <?php } else { ?> <a href="http://www.inkthemes.com"><img src="<?php echo get_template_directory_uri(); ?>/images/1.png" alt="Slide 1"></a> <?php } } ?> </div> <!-- Second Content --> <?php if (inkthemes_get_option('inkthemes_slideimage2') != '') { ?> <div id="fragment-2" class="ui-tabs-panel ui-tabs-hide" style=""> \for example, there seems to be two places that show alt tag for slide 1
Hello, Add alt tag in first "Slide 1" and use same process for other slide also. For example Code: <img src="<?php echo inkthemes_get_option('inkthemes_slideimage1'); ?>" alt="Slide 1"/>
