How to add ALT text to slider images
Discussion in 'Local Business WordPress Theme' started by gypsygal, Sep 27, 2014.
  1. gypsygal
    gypsygal New Member
    Would like to add the ALT text to the images in my slider.. how do i do this?
  2. Yogesh
    Yogesh Guest
    You can add alt tag in slider images to edit front-page.php as shown below in screenshot.
    It will resolve your issue.
    Yogesh Bhade
  3. gypsygal
    gypsygal New Member
  4. Yogesh
    Yogesh Guest
    So your problem has fixed ?
    Yogesh Bhade
  5. gypsygal
    gypsygal New Member
    No I posted above what my code looks like.. it looks a bit different than what you showed me so i wanted to check where to put the alt text.. See above in red
  6. Krish
    Krish Support Staff
    India
    Hi Gypsygal,
    I have just created settings for you.
    Download the attached zip file and extract front-page.php and put this file on your child theme directory or main theme directory as you desire. I suggest you that user child theme for cust, modification for localbusiness theme.
    At last, open the front-page.php from just you have placed on notepad or notepad++ and find the code by following the attached screenshot image and put your alt text for each slider image.
    Hope this will solve your issue.
  7. don3149
    don3149 New Member
    I have the same question about adding ALT Text........
  8. priya
    Have you tried above solution as Mr. Yogesh Bhade had mentioned in his post..?
