How to Add Click to call coding via image link when on mobile
Discussion in 'Cloriato WordPress Theme' started by dilkum, Apr 2, 2014.
  1. dilkum
    dilkum New Member
    Using responsive Cloriato pro theme.
    I want to have an image either on the header or footer area which when clicked on a mobile device allows the viewer to dial the number without having to enter it manually. I just need to know the coding to add to the image link. Also How to Limit this to mobile only users so no errors come up on a desktop display?
    You are asking for the Theme non existing feature, which requires lots of customization in the theme file and time consuming too.
    So it is not possible for us to do that with this theme unless you custom code something up. Sorry.
