How to add contact form to front page???
Discussion in 'ColorWay WordPress Theme' started by chrisr, Apr 18, 2013.
  1. chrisr
    chrisr Member
    Please help I want to place a contact form in the area where the testimonial (block quote) would normally be I have the short code for the contact form and was wandering where I have to place this to get the contact form at the bottom of the page instead of the quote (block quote) that currently shows.
    Please see the screen shot I have attached this is what I want to achieve.
  2. chrisr
    chrisr Member
    Anybody?? can I just add some code to the "testimonial" part in my control panel for this theme or do I have to change something in the front-page.php file??
  3. Nitesh
  4. chrisr
    chrisr Member
    I thought it might have to do with the php file I presume the front-page.php what needs to be placed in this to achieve what I am after as I do not want to use the widget area in the footer unless it can be made white ??
  5. Gourav
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    We will add Contact form 7 plugin at your testimonial area.
  6. Gourav
    To make Your Contact Form Better On Your Website
    You can use "formget-contact-form" plugin, which will help you to make your contact form easily and simple.
    Download it from the link given below.
    http://wordpress.org/plugins/formget-contact-form/
    You just need to register on FormGet, create your form by clicking on the fields and embed the code on your website at any page, post or widget.
    You can easily place the contact form on every page of your website which will increase the user interaction.
    You will be able to manage entire communication from a single place between you and your visitor. It will be easy for you to provide support, feedback to your users.
    We recommend you to try this new contact form solution on your website. Hope it will meet your requirements. You can easily replace the existing contact form with this new one.
    Let us know your feedback
