how to add shortcode on frontpage
Discussion in 'Blackriders WordPress Theme' started by scaadmin, Oct 14, 2016.
  1. scaadmin
    scaadmin New Member
    hello, i want to add a popup ad to my frontpage. where do i add the shortcode from my plugin?
    thank you
  2. Naveen
    Are you using our Popup plugin or Is that from someone else?
    If you are using our Popup Plugin then, you can simply do this from the plugin settings.
    or if you are using Non-InkThemes plugin then, you need to contact your plugin author.
    Warm Regards!
    Naveen Kolhe
