How to add vdo clip
Discussion in 'Forum Rules' started by tarinee, Apr 1, 2013.
  1. tarinee
    tarinee New Member
    I just purchased D'zonia WP theme. I would like to add vdo cilp i.e from youtube to First Feature Section. When I put the site link to it, it doesn't show the vdo clip.
    Please advice.
    Tarinee
    You can add the video clip by pasting the embed code of you tube video in the First Feature Section of your dashboard.
    Follow the steps given below
    1. Open your required video in the youtube website.
    2. Click on the Share Tab present on that webpage below the video.
    3. And then click on the Embed Tab
    4. After that the embed code will display there, copy that code and paste it in the First Feature Section of your dashboard.
    5. Adjust the width and height of that code as you required.
  3. tarinee
    tarinee New Member
    Thank you so much Piyush... You are a Star:)
