How to Adjust Spacing Between NAV and Page Name?
Discussion in 'Cloriato WordPress Theme' started by pd1215, Aug 7, 2013.
  1. pd1215
    pd1215 New Member
    Hi there! Can you tell me how to change the spacing between the main NAV and the page titles? The gap is too large currently and I'd like to adjust it. I have attached a screenshot below to illustrate my point. I am currently using a Fullwidth Page template for this example. The problem is even worse if I insert a breadcrumbs NAV under the main NAV. I just need to know where to set this parameter. Thanks!!
    Paste this code in Custom CSS
    .content_wrapper {
    margin-top:5px;
    Adjust its value as per your requirements.
  3. pd1215
    pd1215 New Member
    That did the trick. You're the man, Gourav! Thanks for your help!! :)
