How to center home page blog content and put it above testimonial
Discussion in 'BlackBird WordPress Theme' started by assistant59, Dec 5, 2014.
  1. assistant59
    assistant59 New Member
    http://www.letouquet.grandhotelbellevue.com/
    1°/ I would like to know how can i center the blog content on home page ?
    So when i got less than 5 blog pages, it will be centered (since i will use blog page for content that change often and will be able for a limited period of time.)
    2°/ Also il would like to put it above the testimonial, how can i do ?
    Sorry for my bad english :)
    Best regards,
  2. Yogesh
    Yogesh Guest
    1. You have to manually manage blog content by applying CSS for 1, 2, 3 or 4 blog post.
    I can help you if you will fix that how many post you want to display at homepage.
    2. I will put the blog section above testimonial, please send us your WordPress dashboard login details also the link of this thread at [email protected]. so that, we can have a look over the issue in details.
    Your website link:
    WordPress username:
    WordPress password:
    This thread link: http://www.inkthemes.com/community/...g-content-and-put-it-above-testimonial.14997/
    Note: When your issue get resolved, you can change your password.
    Yogesh Bhade
  3. assistant59
    First of all, thanks for your fast answer.
    1. I will use this as "dynamic" content that will change very often so i can't tell you how many i will have to use. Cant we just center all the "table" content ?
    Or can you explain it to me for 3 blog post as an exemple ?
    2. Since this is picture and circle are picture too, im not sure of putting it above testimonial, i would like to try before make you do some change that i will not keep. So forget about this but thanks.
    (but you could explain me, i have downloaded wp-editor).
    Thanks & best regards,
  4. Yogesh
    Yogesh Guest
    1. We have to manage that blog post by adding CSS code that will be different for 1, 2, 3 and 4 blog post.
    2. You can try it just go to front-page.php file and cut code from line no. 495 to 557 and paste that code before line no. 418
    It will resolve your issue.
    Yogesh Bhade
  5. assistant59
    1. Ok, can you help me and give me the css code for one exemple ? like for 2 blog post ? Can i add it to my customm css in ur themes options, so i keep the 5 blog post configuration if i delete the entry in custom css ?
    2. Ok will give some try about this later.
    Thanks for your help Yogesh.
  6. Yogesh
    Yogesh Guest
    You have to edit front-page.php file as shown below in screenshot.
    Add <CENTER> code on line no. 508 and </CENTER> on line no. 551
    Then paste the code given below in Custom CSS section
    .feature-post .feature-box {
    float: none;
    display: inline-block;
    Yogesh Bhade
  7. assistant59
    Very nice, i give it a try tomorow !
    As i read (but im not dev) it should work with any number of blog content i think ? Anyway i try it tomorrow.
    Thanks again for your help, nice support here.
    Best regards.
