How To chane language term
Discussion in 'GeoCraft WordPress Theme' started by pablogy, Jan 6, 2013.
  1. pablogy
    pablogy New Member
    I want to change the search button word "Search Listing" to "Search driver". I went to geocrafttheme/lang
    edit default.po and change "Search Listing" to "Search Driver" but it did not change.
    Please let me know how to change it.
    Please check if you have cache plugin installed then deactivate it.
    It will resolve your issue, If not then you can change it manually through
    geocrafttheme\library\text_domains\template_path.php
    line no 35.
