How to Change Colors of Circles Inside Slider Caption Box
Discussion in 'BlackBird WordPress Theme' started by mj_alderton, May 21, 2013.
  1. mj_alderton
    mj_alderton New Member
    I'm wondering how to change the color of the circles inside the caption box on the slider — the dots that show you which slide you're on, which you can click to navigate between slides. I have been able to customize the caption box with CSS code that you've provided on other threads, but I haven't been able to find code for this particular element.
    Do let us know your website link.
  3. mj_alderton
    Unfortunately, my website isn't live at the moment. However, here's a screenshot of what I'm talking about. (The black and one green circles on the right side of the caption box.) Ultimately, I'd like to make the selected slide (the green circle) white so that it doesn't blend into the background of the box.
    Screenshot:
  4. Gourav
    It is not possible to change its color because it is a image not a color, If you want to change its color then, Go to Css > color > images present in your theme directory and replace your image with present pagination image or edit it.
    The name of image is "spgreen.png"
